Hi
First iam going to excuse for my typing
I have an comfort blinker the universal one, and i want to build into my 6n
Can you help me ?
Greeting Trunks
oke who knows the 6N Pinbelegung vom alarmschschalter
THis also an way to connect it
Greetings Trunks
Hi and welcome,
I am sorry, but I dont think I did it get the right way?:
You want to connect a turn signal module (1 tip on the switch - 3 times blinking) into the 6N? Or am I wrong? This should not be a Problem... I will check it out and post the solution here.
Hört sich eher an wie ein Deutscher, der kein Englisch kann
Hi
You are correct i want to install an (1 tip on the switch - 3 times blinking)
Module into an 6n 09-97.
Greetings Trunks
Also aus Großbritanien wird er nicht kommen
Iám form the netherlands..
HI und viel Spaß hier !
Das erinnert mich an Rasenmähen !
Hi thanks
But can some one help me with connecting the relais ?
Greetings Trunks
Hi
wait a moment, @TheKick2005 will give you the introduction / plan to install this system in your car but i´m also interested in such a module.
best regards
...is this the one?
Hello
it is the one form VW itself
Cabel with out the relais
Do you have the number? I also want to install such a modul but i never wanted to install something like in.Pro ore something, original from VW is allready the best!
Greetings Fleck
Hi i orded my set here
Hi guys
i've found the solution ....
connected the relais to alarm light switch
Komfort Relais = Alarm Switch
White-Green = White-green
Green = Black-Green
White = Black-White
Brown = Brown
Black-white =Black -grey
I've connected it at this way and it works perfect
Greetings Trunks
