Kabelbelegung Tacho Polo2F
Polo G60
Polo G60's Polo 2F
Hi Leute, bin verzweifelt auf der Suche nach einem Kabel am Stecker vom Kombiinstrument bei meinem Polo.
Das Drehzahlsignal wird vom Steuergerät generiert und ist auf einem Kabel das ins Kombiinstrument geht - nur auf welchem?
Hat Da schon mal jemand geschaut? Kann das Signla leider nicht an der Zündspuhle abgreifen.
Danke schon mal...
    hi i have the same prop but then in my polo gti 6n2
    i need the rpm wire and not a speed pulse wire
    but i cant find it
    Polo G60
    Polo G60's Polo 2F
    Hi, i'll try it out today - the colours of the cables should be the same in all Polos - if i have some new informations I'll poste it here...
      oo top man
      ps look here too http://www.polotreff.de/html/forum..._f00_688.html
      some wire code's
      Polo G60
      Polo G60's Polo 2F
      Hi again, I have some news for you the rpm-pulse comes fom the "Hallgeber" goes to the engins blackbox and then to your dashboard. At my Polo III it ts an red/black wire in the connector to the tachometer. I don't think that they have changed the colours. So, now I hope I've found the right wire too
      I will test it again when my engine is running again.
        lol oke i found the wire but the pulse signal was to weak i exsplain 1000 rpm on the tacho
        and 100 on the exstra tacho lol so it's 10 times
        weaker then the normal rpm meter so i bought
        a pulse amplifeir but no succes it still wont boost the signal so i'm stuck again
        lol so any who can help me pls
        thks
